help car wont start
Old Jul 10, 2009 | 05:16 PM
jdog_kustoms's Avatar
help car wont start
car shut off pulling out of my drive way pushed it back to the guarge and ran for codes it had a bad crank sensor code replaced sensor with a used one i had in the guarge didnt starts put on a new one from napa still wont start and i cleared the codes on the computor the fuel pump primes up and ideas itwas a new opti when i just rebuikt the motor
Old Jul 11, 2009 | 09:38 AM
Venomous360's Avatar
Stick or Auto?? If its a stick check the Safty switch under the dash. The Big black box.
Old Jul 11, 2009 | 03:28 PM
it turns over but wont start new crank sensor new icm new coil im lost
Old Jul 11, 2009 | 04:55 PM
The crank sensor won't keep it from starting.... its only there for misfire detection.
Why not provide detailed info on your car, using the "signature" feature - year, model, engine, trans and any major mods. That way, people won't have to ask questions about the car before they can help you. When someone does ask a question, its generally a good idea to respond so they can help you. Is it a manual or auto trans?
Post the specific codes you are getting.
When you replaced the Opti, did you loc-tight the rotor screws before installing it? Do you have spark? Have you checked the fuel pressure?
Old Jul 11, 2009 | 05:31 PM
its a 6 speed with stock 30000 mile bottom end ported and polish intake and head 52 mm throttle body 30 # injectors long tube headers cat back under drive pulleys electric water pump new gm opti (didnt loctight screw ) cc 503 cam 1.6 roller rckers computer need to be tuned for change in exhuast and no rear o2 sensor
my buddy cleared the codes before i seen them he said o2 sensor codes and crank sensor
Old Jul 12, 2009 | 12:02 AM
Old Jul 12, 2009 | 04:01 PM
no spark at coil has fuel
Old Jul 16, 2009 | 09:55 PM
i have no spark at the coil or at the plugs and on the icm plug i have 12 volts on terminals a and d but on terminal b i have zero volts
Old Jul 16, 2009 | 10:14 PM
When you say you have fuel, are the injectors pulsing when you try and start it, or do you just mean you have fuel pressure when the pump primes?
Old Jul 16, 2009 | 10:44 PM
how do i check injector pulse i know the fuel pump primes and i can smell fuel when i crank it over and the pink wire on the injectors has 12 volts
Old Jul 16, 2009 | 11:10 PM
The pink wire always has 12V when the key is in the "on" position. The PCM supplies a ground to fire the injector.
You can check for the injectors getting a ground with a "noid" light, a cheap device that plugs in between the harness and injector and flashes when the injector get the ground to fire.
Have you rechecked it for codes? The code for the low resolution pulse from the Opti will shut down the fuel system. You'll get a few pulses of the injectors when you try and start it, but after the engine turns two rev's with no low res pulse detected, the PCM shuts down the pump and injectors. But if you don't have the code, its not the optical cam position sensor in the Opti.
You might want to add a "signature" with basic info about your car... year, model, engine, trans and any major mods. That provides people with the info they may need to help you. Not all years are the same in all respects.
Old Aug 10, 2009 | 02:48 PM
found out whats wrong with the car look at these pics WONDERFULL OPTI
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
