Help! car wont idle
Old Jun 6, 2003 | 04:10 PM
KeVMaN's Avatar
Help! car wont idle
I went out to start the car this morning, and it just kept turning over. gave her a tiny bit of gas and it started fine. let go of the gas, and it chugs along at 3-400rpm for a sec then dies. the car still runs absolutely perfectly, just have to keep my foot barely resting against the pedal. is it a loose throttle cable or is there some way to turn up the idle or something? ideas will be appreciated. thanks
Old Jun 6, 2003 | 04:26 PM
sssalah's Avatar
Your iac could be stuck.
Old Jun 6, 2003 | 04:34 PM
InjectedSS's Avatar
youve got a vacum leak somewhere! check all your hoses on the intake! check the power brake booster hose etc
Old Jun 6, 2003 | 07:41 PM
KeVMaN's Avatar
well, i adjusted the screw that holds the throttle lever thing out so it stays at about 5-600rpm. if it starts to drop again i'll know somethings wrong. thanks for the suggestions
Noenav
Mar 1, 2019 07:38 AM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
