Help! Car won't crank at all
Old Oct 28, 2004 | 12:37 AM
speed fiend's Avatar
Just got off of work and went to start my car but... nothing. No cranking, no sounds what so ever. All accessories go on but when I go to start, it's as if I'm turning the ignition with out pressing in the clutch. I know it's not a battery issue, so what do you guys think? When I tried to jump start it, the car started for like a second then died. Also the security light keeps flashing but I don't remember if thats normal during the ignition start position.
Any ideas? I really don't want to have to tow it to get it fixed.
Old Oct 28, 2004 | 12:46 AM
Silvershark's Avatar
Re: Help! Car won't crank at all
starter? CAGS?
Old Oct 28, 2004 | 12:48 AM
FryedClutch's Avatar
well this happend to me not to long ago unfortunatly you have a bad ignition lock cylander ( at least i think thats what its called) the security light is supposed to go off you need to either take it to a dealer and have a new one put in and get new keys with it ($400) or get a custome tune and have the vats removed
when this happend to me i tried push starting and everything and it would turnover and then die cause it thinks your trying to steal your own car but also try diconecting the battery for about 20 mins so the comp can reset that might fixitt but good luck
Old Oct 28, 2004 | 12:57 AM
CAGS was supposed to equal VATS. Brain fart on my end. Damn abbrvations.
Yah, that security system is a pain in the ****.
Old Oct 28, 2004 | 01:00 AM
i hear yah after i spent the cash to get the new lock cylandar put in it happened again but then i just let it sit for a few i got really T'd off and then tried to start it again and i worked so you might be in luck and find after awhile and a battery disconect that it will work again but mine didnt work for 20 hours
but i know when i get my tune im gettin that BS VATS takin out so it doesnt happen again
Old Oct 28, 2004 | 02:06 PM
Thanks for the reply! I'll try the battery disconnect and see if that works. $400 for a new lock cylinder? OUCH! Now I'm really hoping the car will start.
Old Oct 29, 2004 | 12:41 AM
well im glad i could be of some assistance but if it wont start i would seriously checkout pcm for less and see if the VATS delete will fix this for you and ifso that will be much cheaper plus you get a tune which will add some power so its a win win situation but best of luck to ya
Old Oct 29, 2004 | 07:55 PM
R8E1D's Avatar
The Lock cylinder replacement isnt that much, roughly $150 for the parts (cylinder and two keys) and $30 for the two tools to take the steering wheel and the retainer spring off( I bought mine at advance). And if you dont already have one buy a Haynes manual, step by step took me about an hour to do it! Good Luck!
Red
Old Oct 29, 2004 | 08:38 PM
Right on! A friend of mine hooked me up with a lock cylinder kit for $120 and $70 for labor. I was dreading the thought of doing the work in the hot, tight parking space of my work place. Also got the free towing service, thank god for road side assistance. I guess that stuff isn't a total waste of money after all.
Thanks for the help.
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
1996LT1Z28
Dec 1, 2014 01:01 AM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
