help, car turned off for no reason while driving?
Old Sep 5, 2006 | 08:17 PM
street demon2k3's Avatar
i just took my car down the street and it just turned off for no reason. i was driving and it just turned off, started it again and drove like 2 ft. motor turns over but it doesnt start, i really dont know what it can be. need some help and maybe some tips for troubleshooting. any help is appreciated
Old Sep 5, 2006 | 08:22 PM
rockstarjoey's Avatar
Re: help, car turned off for no reason while driving?
try checking the ignition fuse in the box......mine did the same and replaced the 10 amp with a 15 amp....never had the problem again!
Old Sep 5, 2006 | 08:28 PM
was the fuse burned out or anything, or did you just replace it. how did you come to the conclusion that the fuse was the problem? i'll double check it and get back in a few minutes.
Old Sep 5, 2006 | 09:08 PM
bombebomb's Avatar
My car did this, and at the time it was the coil, it would die, and would not start back up. Them are my .02 cents, but id listen to others before me.
Old Sep 5, 2006 | 09:25 PM
Hark_z's Avatar
I just went thru this as well with the coil.
Old Sep 5, 2006 | 09:29 PM
Ellis's Avatar
My Formy has done this a few times. My connector to the Opti is cracked at the tab that keeps it from backing out. If I push it down with the tip of a screwdriver, then the car will fire right back up. I should just replace the damn thing, but being a basically lazy person, doing that every 120 days or so doesn't seem like too big of a deal.
But it's on my "to do" list for the next time I'm down in there for something
Old Sep 5, 2006 | 09:47 PM
well i checked the coil for spark and it was o.k. then i turned the car without the MAP sensor. so i connected it back on(MAP) and the car started and idled the way its supposed to. left the car on for like 10 min to see if it turns off and nothing, so i drove around the block and like 10 seconds after the car just died. let it sit for like 3-5 min and it turned back on, so i left it idling and just called it a night. when the car was idling the coil was arcing pretty bad and got worse if i turned the throttle with my hand. i dont know what might cause this and im thinking that the ICM is f*<ked up. cuz everytime i let the car sit for a few min it turnes back on in an instant. the fuel pump sounds strong and everything else checks out. any ideas??
Old Sep 5, 2006 | 09:50 PM
oh BTW the coil is a brand new MSD Blaster unit and have replaced it two times. also had 2 new stock replacement coils as well. so i can rule that out since all these were replaced within the last month or so.
Old Sep 17, 2006 | 10:25 PM
Bow94z's Avatar
stil have this problem?? Your explaination is the SAME situation im in right now
Old Sep 21, 2006 | 12:05 AM
everything checked out fine coil, ecm and all but the damn connector that goes to the coil wasnt going all the way in. since i have a dual connector one side was alright and the other was 1/2 way in, so when i made a sudden turn or stop the connector would come loose.
Old Sep 21, 2006 | 04:57 AM
Heatmaker's Avatar
Advanced Member
I wish I knew... also. These are mystery problems with these cars.
Old Sep 21, 2006 | 05:55 PM
my car has given me all sorts of problems since i put the new 355 in, it seems that the car will never run cuz everytime i fix something that's wrong with it something else gets F***ed up. i figured out the miss it has and now i was going to drive it around and get the plates, inspection sticker, and insurance but now my damn brake lights dont work i dont know what caused it. its really frustrating
Old Sep 21, 2006 | 08:03 PM
socalchris2002's Avatar
Mine shut-off twice while I was driving on the freeway, luckily It started back up while still moving. I plugged in my code finder and 16 came up which is an ignition problem, like low resolution or something.. I replaced the opti like a year and a half ago and was wondering if there's some problem with the ignition part where you put the key in to start it, or should I just replace the harness connector that goes into the opti?? I don't want to go through all the trouble to replace the opti again.. its frustrating since I need to get to work and don't want to be on foot again! would be gratefull for any advice, thanks
94 Z28 6spd
K&N
plugs & wires replaced 1 1/2 ago
replaced catalytic converter
Old Sep 22, 2006 | 06:01 AM
01Z's Avatar
01Z
If it is the ignition switch then you can find illustrations on the component location and some tips from Shoebox. Go here -> http://www.shbox.com if you want take a look. Good luck and tell us how you make out.
liamcg97
Nov 25, 2019 05:55 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
