help car quit yesterday
Old Oct 1, 2003 | 09:07 PM
Blownbird355's Avatar
Drove my car yesterday for the first time after opti replacement. Drove car bout 5 mile and it died. I restarted and then stopped to get gas. Went to start again and it would run then quit. I did get it to run awhile but everything was cycling like it was loosing power and regaining power. Checked batt and alt connections. I believe it is PCM or possibly a ground prob havent checked that. The cycling is not random but even period between each cycle. Thanks.
Old Oct 1, 2003 | 09:08 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Did you make sure that the opti was 100 % flush up against the block? And are you throwing any codes?
Chris
Old Oct 1, 2003 | 09:38 PM
nas-T-72z's Avatar
had that prob when i replaced my opti. it would do the exaxct same stall hard starts and stumbling. cleared my codes and cleaned off the connecter on the water pump sensor/plug and its ran great since..
Old Oct 2, 2003 | 11:01 PM
I really think it has nothing to do with the opti pointing more towards the PCM or a ground because off the relays cycling constantly. Going to see if Datamaster will communicate tomorrow.
Old Oct 3, 2003 | 11:33 PM
Put car on scanner today with datamaster, just logged with key in run position but not running and it said bad checksum, checked the edit file I loaded and the checksum was good.
Old Oct 3, 2003 | 11:55 PM
QCKZ28's Avatar
imo recheck that you installed the opti right. if the problem just started after changing the opti its most likely the opti
Old Oct 4, 2003 | 04:36 PM
Well it ended up being the opti in a way. Its the opti harness. Wiggeled the harness around and it started.
Old Oct 4, 2003 | 04:44 PM
crazyjoe's Avatar
So Rob, is the car good to go now?? Have you driven it since then?
Oh, I took the Z and had the exhaust leak fixed. Charge up your laptop so we can get a full scan on this thing Let me know when you can do it. Chris mentioned hooking up a factory computer to see how it runs on stock programming, what do you think...........shoot me an email.
Joe.
mr28
Apr 20, 2016 05:44 PM
MadMav
Feb 6, 2015 11:02 PM
fpete1992
Dec 11, 2014 03:51 PM
USAirman93
Nov 24, 2014 03:37 PM
mr28
Nov 23, 2014 11:11 AM
