Help! car overheating
Old Apr 2, 2004 | 12:04 AM
  #16
JJJ93z's Avatar
Originally posted by 88RX7LT1
JJJ93z is absolutely correct. The smallest amount of air in the reverse flow system (unique to our LT1s and othe modern engines) will cause a lock in the flow.
thats what i was trying to say , (about reverse flow cooling)
The bleeder on the thermo housing should be bled first. The unfortunate part about the process is that the coolant will leak directly onto your opti-crap.
stuff a towel inbetween h20 pump and opti ( just to cover up a bit) wet nonvented opti + hairdryer= time of your day wasted jus to get car to run!
Good luck, and bleed the system in steps. It sounds funny, but even little bubbles in the system can hinder the flow. Trust me; I've been there recently.
do u have pics of your rx7? my buddy is considering doing lt1 in rx7 .
Old Apr 2, 2004 | 12:54 PM
  #17
RyanS_Z28's Avatar
so we replaced the thermostat, temp is still climbing. we checked the sender like you said and it seems to be fine. we checked fuses and relays and those look ok. we also know the fans are coming on. i do have an aftermarket electric pump. is it possible that it has gone out? the temp climbs fairly rapidly all the way to 260 so something is def going wrong
Fans DO work
Thermostat APPEARS to be working.
Valves WERE bled for air
Water pump?
Old Apr 2, 2004 | 02:02 PM
  #18
grygst76's Avatar
Fans DO work
Water pump?
That seems to be the last thing on the list and is usually the one that;s wrong, as long as no coolant is leaking or missing, and thermo is fine and such you have a bad water pump
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
