HELP!!! Car died, won't run! Optispark?
Old May 12, 2004 | 11:49 AM
LT1Formulation's Avatar
Last night I was driving my formula around and parked it after driving for awhile. When I got back in to take off again, it started but wouldn't rev up... it sputtered and would continue idling but give it gas and it would just die. I checked the Schrader valve on the fuel rail and it's got full pressure so it's not a fuel delivery problem. It finally stopped running altogether and it will not start back up. Is the Optispark the problem? I haven't had any problems with it since I bought it, other than an off idle hesitation. It was running perfectly fine up until that point. Is there anything else it could be besides the Opti? I ordered an Opti in just in case, but I don't want to install it if it might be something else. Also, since my car is a 93, it has the older style Opti in it, should that be upgraded/can it be upgraded? Any info would be greatly appreciated as this is my only car right now.
Old May 12, 2004 | 01:54 PM
badblackta's Avatar
sounds like an opti to me. my friend is having to replace his, and I think mine is about to go Go ahead and put the new one in and you will be good to go.
Old May 12, 2004 | 01:59 PM
Red96Lt1's Avatar
It can be upgraded, but with alot of work. You have to have a new timing cover and chain. Also I think you have to have a newer style cam, as well as poke a hole in your intake elbow.
Old May 12, 2004 | 02:35 PM
Can you tell the difference between a 15psi and a 30psi spew from the schrader valve or did you actually put a test gauge on it? Might be the opti or something else, but you have to accurately rule out stuff to keep from chasing your tail. Have you checked for spark?
97SSdude
Dec 31, 2014 07:43 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
MJ_Z28
Aug 7, 2002 07:15 PM
