HELP!! can not turn motor over
Old Jan 28, 2003 | 08:54 PM
VINCELEE123's Avatar
just put new motor and auto trany in the car and i went to adjust
the valves and put piston#! at TDC i couldnt turn it by the
harmonic balancer. the motor turned by hand when it was
outside the car. also the heads are on it and the spark plugs are
out, am i missing something?
thanks vince
Old Jan 28, 2003 | 09:07 PM
AZ2ENVY's Avatar
This might seem like a stupid question but do you have the transmission in neutral ?????
Old Jan 28, 2003 | 09:08 PM
magius231's Avatar
how are you trying to turn it, by hand? it takes about 60lbs/ft to turn your standard small block by hand...so either you need to get a breaker bar on it and try that, or something is hung up inside the motor.
Is the starter on? Is it locked up? Something locking the flexplate/flywheel?
Old Jan 28, 2003 | 10:01 PM
problems
ok, the starter is off, when you mean use a cheater pipe are you refering to puttining it on the center bolt on hub??
when i try to turn this bolt it just keeps tighting it.
the shifter is not hooked up, the car rolls so i dont know.
(no its not a stupid question because im lost now and anything will help).
the flywheel and tq converter will not move as well.
vince
Old Jan 28, 2003 | 10:19 PM
Re: problems
vince
Make sure it is in neutral or park and be careful about putting too much torque on that balancer bolt. Be warned. They can snap or you can strip the crank threads.
I hope you are sure that you got the timing gears lined up properly. Try turning the engine backwards to see if you get any movement. You will not be able to use the crank bolt. You will have to try to wrestle the pulley or pry at the flywheel. There also is a tool you can get that will let you use the flywheel teeth to turn it. It has a long arm and will give plenty of leverage. There also is a tool that bolts on the front of the balancer in the 3 bolt holes that will let you spin the motor.
Old Jan 28, 2003 | 10:31 PM
timing gears
when you mean them you mean dot to dot
so dont turn by balancer?
Old Jan 28, 2003 | 10:38 PM
Re: timing gears
Yes, aligning the dots on the gears.
All I am saying about the balancer is, that if the motor seems locked up and you put a big honkin' cheater bar on there to turn the crank bolt, you are asking for big trouble. I am even curious now if the crank bolt is not stripped. Try turning it by other means, but don't use the starter if it is locked up. You will break the starter housing.
I don't know if your engine is of stock variety, but was it spun with the pan on it, before it was put in the car? Any chance of pan clearance problems?
Really, I think trying to spin it backward might tell you something, if it actually will go backwards.
Old Jan 28, 2003 | 10:43 PM
sids
yes it spun with pan on, the bolts not stripped
yet, that was why i was afraid to put cheater pipe on it.
Old Jan 29, 2003 | 12:33 AM
Unhappy tranny
when we put the tranny on is there anything that could have locked the flex plate?
put shifter on and now is in neutral and still does not turn
Old Jan 29, 2003 | 12:49 AM
Capriceforever's Avatar
did you build the motor yourself? or was it a complete drop in?
Old Jan 29, 2003 | 12:54 AM
no
the machine shop built the bottom end,
i put the cam, heads ect. on the motor.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
formula79
26
Aug 5, 2002 12:21 PM
