HELP! barely starts after cam
Old Dec 12, 2003 | 04:24 PM
  #16
jj93z28's Avatar
no spark?
Well I backed off all the rockers... no effect I checked the cam timing it is right on. However I don't seem to be getting any spark to the #1 plug(only one I checked so far). Why would I not have spark???
Old Dec 12, 2003 | 05:54 PM
  #17
96 WS6's Avatar
opti???
Old Dec 12, 2003 | 07:01 PM
  #18
kevmor99's Avatar
check others to see if its the coil etc.
Old Dec 13, 2003 | 03:31 AM
  #19
93formula's Avatar
did you also tuen it for a hot cam? its a 93 right.
Old Dec 13, 2003 | 07:37 AM
  #20
jj93z28's Avatar
Well I had my old coil sitting around so I switched the two... still the same problems. I am getting some spark, when you crank the engine occasionally it starts to fire and then quits. No I have not had the car tuned yet.
Old Dec 13, 2003 | 10:15 AM
  #21
kevmor99's Avatar
Is it sparking on all cylinders? Or when it tries to start is it just a few making it die? You got everything plugged back in right after the install?
Old Dec 13, 2003 | 02:56 PM
  #22
BoneStockRacing's Avatar
A 93 car running anything but a stock cam will run like absolute *** with out tuning. Madwolf or someone from PCMforless explain this please.
Old Dec 13, 2003 | 06:16 PM
  #23
jj93z28's Avatar
So it could be tuning??? Yep everything is plugged back in and yes occasionally it does fire but will only run above 1500-2000rpm(real choppy).
Old Dec 18, 2003 | 01:01 PM
  #24
jj93z28's Avatar
Well I have tried a new coil and new ignition module neither had any effect. Could improper tuning cause the plugs not to fire?
Old Dec 18, 2003 | 01:23 PM
  #25
Fastbird93's Avatar
I actually was running the stock tune on a ported head/hotcam 93 for a very short time and it ran fine.
Old Dec 18, 2003 | 02:24 PM
  #26
LT1TONY's Avatar
I've also ran the stock tune on a ported head/hotcam '94 and sprayed a 175 on top of it and it ran fine.
Old Dec 24, 2003 | 06:05 AM
  #27
scoobysnax83's Avatar
Something went wrong on the opti install....
Old Dec 24, 2003 | 08:38 AM
  #28
Scott 97 Z28's Avatar
Just FYI...
If the engine sits for awhile the lifters will bleed down. Tightening to zero lash with colapsed lifters is too tight. I had to readjust mine after running the engine for awhile and building oil pressure.
Old Dec 24, 2003 | 08:53 AM
  #29
Originally posted by Scott 97 Z28
Just FYI...
Ironically enough, I had my entire engine apart down to the block for almost 3 weeks. When I put it all together, I left everything as is and did the zero lash then 1/4 turn on all of them. (Making sure that they were all in the closed position of course) And it was a perfect adjustment. I didn't build up the lifters at all. Now, I know what you are saying. That they will be too tight, but either mine didn't bleed down for some reason or it was a freak occurence. I don't know if it was in this thread or not, but adjusting valves is almost a black art. Some people have the talent and some do not.
Old Dec 24, 2003 | 08:55 PM
  #30
meengreen 94z's Avatar
Are you sure you installed the opti dowel pin correctly? It should have slid in with NO resistance. I made this mistake and the car did exactly what you described..
