HELP Any one who has installed a Torsen diff from SLP
Old Mar 20, 2004 | 09:46 AM
radarb8's Avatar
Question HELP Any one who has installed a Torsen diff from SLP
I bought a torson diff for SLP and I need to know before mon,it's going to be installed mon with 3:73 gears,did you loose the ABS because the relocater gear can't be installed on the SLP diff or is what I have been told not true
Old Mar 20, 2004 | 11:31 AM
KENS96M6's Avatar
I had a take out torsion diff. from SLP and the ring and abs worked fine. Be very careful removing and installing the ring from the old diff. They crack easly.
Old Mar 20, 2004 | 11:34 AM
dkeers's Avatar
I just did it this week. The reluctor wheel works fine on the torsen differential. My only problem was that the cross shaft in the differential would not come out once the gear was on (it would barely hit the ring gear teeth). I had to grind the shaft a little bit to gain enough clearance to be able to get it in and out whilie the gear was installed. I have not heard of anyone else having this problem. Let us know how it goes.
Dustin
Old Mar 21, 2004 | 09:04 AM
radarb8's Avatar
thanks
Thanks guys , this site is invaluable for information .
Nov 18, 2023 07:21 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Richardan15
May 30, 2015 08:36 AM
Don 97 SS
Jul 11, 2005 08:50 AM
