HELP! Air Conditioner Drain Clogged
Old Apr 5, 2003 | 08:29 PM
Raider Z28's Avatar
My drain plug for the condensation is not draining. When I run the Air Conditioner and make a left turn it drains water into my passanger floorboard. I looked everywhere under thte car for the drain hose, but cannot find it. I pulled the panel off just below the glove compartment and it appears to be draining from the left side of the passanger footwell just under the center dash.
How do I fix this??
Old Apr 5, 2003 | 11:04 PM
There is no hose, just a hole for the condensate to drain out. You can do whatever you can to mechanically open it up.
Old Apr 6, 2003 | 01:56 AM
bp's95formula's Avatar
Just get the A/C delete pulley
gillta95
May 8, 2015 07:46 PM
kksi
Feb 17, 2015 10:41 PM
David Dorris
Jan 17, 2015 08:10 PM
95chwagon
Jan 13, 2015 09:19 PM
Sandersen511
Jan 13, 2015 03:49 PM
