Help again with schraeder valve!
Old Jul 9, 2003 | 12:08 PM
RealQuick's Avatar
Does the fitting for a fuel line thread on the outside or inside or the spout on the fuel rail (where the schraeder valve was)? I need to know ASAP! I am installing elect. fuel press. gauge and need to route sender, so I am using some fuel line.
Old Jul 9, 2003 | 12:54 PM
JSK333's Avatar
I'm pretty sure that the threads on the fuel rail fitting are on the outside (male).
Old Jul 9, 2003 | 12:58 PM
RealQuick's Avatar
So is the AN4 fitting the wrong one, or did the mustang guy give me the wrong one?
Old Jul 9, 2003 | 01:15 PM
Sparkz28's Avatar
its not a AN fitting....its NPT......
Old Jul 9, 2003 | 01:27 PM
Sparkz28's Avatar
sorry its An-4....I had a brain fart!
Old Jul 9, 2003 | 01:43 PM
The Schrader is -4AN male, which means you need a -4AN female fitting to screw onto it (after you remove the core from the Schrader). Your fuel pressure gauge sender will be 1/8" NPT male, so you need to convert from one to the other.
The way I did it...
NOS Part # 17535 -4AN female x -4AN male 90-deg swivel fitting. This gets the connection pointed away from the cowl, and allows you to rotate the fitting on the Schrader without damaging the Schrader. It is only swedged on and will break off very easy.
-4AN braided hose from -4AN swivel fitting, to a 1/8" NPT brass coupling. NOS makes a 24" -4AN hose with -4AN on one end and 1/8" NPT male on the other.
-screw gauge sensor into the brass coupling, and tuck it away, behind the PCM. The wires can go from the pressure sensor through the big rubber grommet behind the PCM
Old Jul 9, 2003 | 01:47 PM
RealQuick's Avatar
The way I did it...
mmm, yummy info ... thanks!
Old Jul 9, 2003 | 01:56 PM
JSK333's Avatar
I used the NOS swivel Fred recommended (thanks again Fred), but I went straight to a 4AN T fitting, that then goes to my NX fuel solenoid and an 1/8" NPT fitting for my FP sender. It's been very sturdy so far, so I don't know if you really need the extra length of hose or not. Your choice, I suppose.
Old Jul 9, 2003 | 01:59 PM
RealQuick's Avatar
Thanks everyone for chiming in. Hopefully the local shop will give me the right stuff!
Old Jul 9, 2003 | 02:03 PM
Bonus info....
Photo of NOS Swivel fitting on Schrader Valve
Old Jul 9, 2003 | 02:04 PM
RealQuick's Avatar
Bonus info....
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
