help! 95 lt1 white smoke...
Old May 6, 2010 | 11:47 AM
  #16
Defore's Avatar
lol i know right i guess it was just one of those days... but just enough water to fill the air pump and iv replace the oil twice since then just in case. figure something that simple didnt work. but i found someone thatll do it for $300 cuz i just dont have the tools or time to do it in my college apartment parking lot lol
Old May 6, 2010 | 12:31 PM
  #17
Originally Posted by Defore
........ now im back to where i was. but the water is coming from the top v looking area in the throttle body and sucking back in. and that would make since for the compression to be fine when its cold since it doesnt smoke till hot. it just seems like sooo much water to be coming out of the throttle body like did my head gasket just disappear all together good god.
The location you describe in the throttle body is the location of the hole that goes up into the top chamber on the throttle body.
As already explained (in less detail), if you have excessive blowby, or coolant entering the oil, as the engine heats up the moisture is driven off, the pressure builds up and the water vapor vents out of the passenger side valve cover, through the vent hose to the connection on the side of the throttle body, into the top chamber, and if you had enough water (hard to believe, but apparently its happening) it would drip out the hole on top of the "V" between the throttle bores, and would be sucked into the intake manifold, and then into the combustion chambers = white smoke.
Old May 6, 2010 | 12:39 PM
  #18
FastandBlue's Avatar
Yeah, I'm in the same boat. I go to college in Eastern Washington, but luckily I have a relative that owns a house and garage (but doesn't stay there) that I use when I don't want to work outside of the dorm parking lot. I have most of my auto tools here, though.
But yeah, Injuneer knows what's up. It does sound like you are having a problem with coolant in your oil, but you said you DON'T have any white smoke our the exhaust, right?
mr28
Apr 20, 2016 05:44 PM
Jason Short
Jan 19, 2015 06:34 PM
NewsBot
Dec 24, 2014 11:05 PM
mr28
Nov 23, 2014 11:11 AM
