help on '94 opti vacuum lines
Old Sep 20, 2005 | 05:00 PM
95lt1a4's Avatar
i recently purchase a 94 z-28 a-4 and it is pretty much a pig. 9.28 1/8 mile.the only mods are moroso cia and flowmaster muffler.i got to looking at the opti and one vaccum line goes about 3/4 way back in the intake.the other is dangling!any ideas on where it is suppose to go?i've looked pretty good and kind find anything off.also how do you tell vented from non vented.mine is a late 94(6/94).thanks
Old Sep 20, 2005 | 05:04 PM
v8pwrdz28's Avatar
Re: help on '94 opti vacuum lines
i thought the 93-94 optis didnt have any of the vacuum line,s i thought that was 95+.
Old Sep 20, 2005 | 05:06 PM
95lt1a4's Avatar
i've heard it both ways.i heard that the late 94's had vented opti.is that the difference?
Old Sep 20, 2005 | 05:12 PM
On the f-body, I know of no use of the vented opti before 1995. Maybe this 1994 had a conversion done to it.
You can find pictures and diagrams of the vented opti system on my Tech Page.
Old Sep 20, 2005 | 05:52 PM
95lt1a4's Avatar
hate to sound really stupid,but i can't tell by the diagram either.the line with the check valve is attatched correctly.the other in the diagram looks like it goes under air intake duct.i took the duct loose and can't see anywhere for it to go.thanks for your help,i like your website!
Old Sep 20, 2005 | 09:11 PM
95lt1a4's Avatar
is the other line just a vent?car does moroso have cold air intake.maybe it went on the factory setup?
Old Sep 20, 2005 | 10:04 PM
http://shbox.com/1/opti_vacuum_conn.jpg
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/1/opti_vacuum_hose.jpg
http://shbox.com/ci/opti_vent.jpg
Old Sep 21, 2005 | 08:03 AM
95lt1a4's Avatar
thanks,guess i didn't look far enough on your site .my intake elbow doesn't have the place for it to go.i guess it being a 94 something has been changed.i understand what to do now.
Old Sep 21, 2005 | 08:24 AM
Do the connections on the Opti look like the factory parts in Shoebox's pictures? There is a site that shows how to "convert" a non-vented Opti to a (sort of) vented unit. Involves drilling holes and epoxying connections on it. Maybe someone did that to your Opti.
I have a VERY late 1994, one of the last ones built, and it left the factory with a non-vented Opti.
Old Sep 21, 2005 | 08:29 AM
If that is the stock elbow and it does not have the port for the opti fresh air inlet, then you know it did not come stock with a vented opti. You can just poke a hole in the elbow to be able to plug in the vacuum barb (you might want to put a dab of RTV on it).
HectorM52
Jul 30, 2017 11:46 AM
Patrick Kovack
Mar 8, 2015 09:26 AM
grgguy
17
Feb 23, 2015 07:57 PM
pologreen97z
Dec 2, 2014 10:42 AM
