help!!!!
Old Jul 18, 2006 | 12:34 PM
craigbeydler's Avatar
help!!!!
ok i have a 93 z28 rebuilt 5.7 2800 stall 3.73 gears 3 inch flowmaster and a aftermarket chip
ok started it the other day ran fine got half a block from my house and it just dies and wouldnt start. would only crank. let it sit a couple days and it fired up and did the same thing
please help with any suggestions whats wrong
thanks
craig
Old Jul 18, 2006 | 12:38 PM
"White Knight"'s Avatar
Re: help!!!!
What does it do when you try to start it and won't? Does it crank over?
Old Jul 18, 2006 | 12:48 PM
Re: help!!!!
yeah it will just crank. i let it sit a couple days and give it a little gas and it fired up than drove a bit and just died
Old Jul 18, 2006 | 01:33 PM
onetransam4u2nv's Avatar
Re: help!!!!
sounds like your pump is priming but not maintaining pressure put a gauge on the shrader valve and see what it reads.
Old Jul 18, 2006 | 03:13 PM
Re: help!!!!
thank you
i will try that when i get off work
Old Jul 18, 2006 | 03:33 PM
Re: help!!!!
Since you have a 93, you can check the ECM for codes by shorting the ALDL connector and flashing the codes on the SES light. Might show you a stored code for the problem that prevented it from starting.
