Help
Old Jun 21, 2004 | 10:52 AM
gritter's Avatar
Help
When im at WOT and my car is above say 3,700 rpms i get a very hard vibration from the gear box. It sounds kinda like grinding, but it never does it when im only gradually pressing the gas? Does it in the 1-2 shift and the 2-3 shift, it'll rattle the change in the cup holder it's so bad. Any ideas on what could be happening?
posted this in the transmission section anfd didnt get any replies thought i'd try my luck here,
Old Jun 21, 2004 | 02:06 PM
gritter's Avatar
more info... I can hold the gas 3/4 down and bring the car up to 5-6k with no grinding, the only time it grinds is when im at WOT, any clues?
Old Jun 21, 2004 | 03:22 PM
valter's Avatar
What is your car? Sounds like misfire to me... No SES light?
Old Jun 21, 2004 | 03:24 PM
gamecockfan04's Avatar
Maybe an out of balance Driveshaft.
Old Jun 21, 2004 | 04:04 PM
gritter's Avatar
it's a 94 trans am, i dont think it's a misfire, it a like grinding from under the shifter.
Old Jun 21, 2004 | 06:22 PM
This may sound dumb, but check your tranny mount. If its broken, or on the way out, when under WOT its allowing the tailshaft of the tranny to lift higher than normal and can cause clunks, bumps, and all kinds of strange noises. I just replaced mine and it was the last thing I would have thought to check and my car runs like a champ again.
Old Jun 21, 2004 | 07:27 PM
gritter's Avatar
anybody have a pic of the tranny mount so i know what to look for?
Old Jun 21, 2004 | 08:12 PM
valter's Avatar
Yep, it's possible to be a tranny mount. Can't find any picture, but it's pretty easy to locate it - look under a car from driver side and locate a place where tranny is supported. But it's not easy to say whether it's good or bad from that point of view Reference for changing it you can find here http://www.fbody.com/tech/details.cgi?id=38 If you decide to change it, consider poly mount.
Old Jun 21, 2004 | 08:14 PM
I cant find any pics of a mount under the car, but get underneath your car and its right in the middle (where your console is) and bolts to the tailshaft of the transmission. You'll see the crossmemeber which runs door to door and the tailshaft rest on the mount which is in the middle of the crossmember. I included a picture of what the mount looks like and if its broken you will be able to easily manually push the tailshaft of the tranny up when under the car. http://www.zmydust.com/images/crossandmount/mount2.jpg
Old Jun 22, 2004 | 03:33 AM
gritter's Avatar
any body have a direct link to where to buy this part. im having trouble finding it
Old Jun 22, 2004 | 08:02 AM
I got mine from AutoZone with a lifetime warranty for about $18. They also have the Poly mounts, which I bought a few weeks ago, but I hated it a swapped it back with a rubber mount after 2 days of driving with the poly one. It made my car vibrate so bad and the noise was awful, and basically made my car feel as if it were going to blow up. With the rubber mount it runs smooth and drives great again.
Old Jun 22, 2004 | 08:26 AM
valter's Avatar
Tranny mount from gmpartsdirect.com, part# 22201140. I personally went with Energy Suspension Poly mount - car feels much better right now, no vibrations. But I have 1LE alum DS in perfect balance.
Old Jun 24, 2004 | 11:23 AM
gritter's Avatar
went under the car today, the trailshaft moved but not easily.
Old Jun 24, 2004 | 12:18 PM
Well I shouldnt have said easily,but if you see the mount strectch alot while lifting it its broken.
Old Jun 24, 2004 | 01:14 PM
gritter's Avatar
i did however notice the tranny is indeed hitting the floor, i could tell this because there was a piece of like grinded metal on floor above the tranny.
