Heater Hose assembly...
Heater Hose Assembly
OK, here's what I'm planning to do: replace hoses #12, #15 and #20; carefully remove the clamps (#16's) and replace with regular hose clamps and reuse the reducer (#13).
Part numbers needed to buy:
#12 = 10188037
#15 = 10146991 (is this only the sleeve or the hose/sleeve together?)
#20 = what's the PN?
When I called the dealership last Friday they said they didn't sell these hoses separately, and that no one did so I'd have to buy the entire assembly. If the GM dealership won't sell me these separately, where can I get them from? NEVER MIND, I just called Jason.
http://shbox.com/1/heater_hoses.jpg
#12 = 10188037
Would cutting completely through the pipe be totally unheard of? (just cutting off the connector altogether) I'm sure the end of the metal pipe has a lip of some sort and their may not be enough room afterwards to slide the new hose and clamp down on....just a thought.
Actually I removed the aluminum crimp on factory clamps with nothing more then a good pair of channel locks and a flat head screw driver used to pry it back a little. It worked great and the crimp fitting folded and peeled away like butter, and a full on Dremel would almost make it too easy lol.
FWIW, I have all 5/8" or 3/4" heater hose in place of most of my heater core and oil filter heater lines, reusing the factory metal tubes and it works great for me.
I did exactly what he did, replacing all the hoses with stock from Autozone. They do have correctly angled hose for the few areas on the LT1 where you have to have a special bends or turns, but most of the hoses on my LT1 are stock hoses cut to fit and zip tied in place. Slow, tedious work, but I think it cost me about $25.00 complete! Heck, the hardest part was bleeding the system after refilling the radiator / engine with coolant! Do yourself a favor, though - flush the system before you take off the old hoses, then responsibly dispose of your old coolant. Might not hurt to change your heater core to a new one - you won't believe the crud that can build up in the old core. Believe it or not, it's about an extra hour's worth of work when you're changing the hoses anyway. And it's the easiest heater core swap I have ever seen! Good luck, just use your time and elbow grease! If you do it my way, you'll spend about a hundred bucks, but you could be saving a radiator change later on!
