Heater hose?
Old Nov 14, 2008 | 10:14 PM
neil350's Avatar
Heater hose?
I have been smelling coolant but none hits the ground, if the car is at operating temps and sits at a light for a few seconds and then accelerates can smell the distinct smell of coolant being poured on some thing hot. So Imagine its pooling and then when the car moves splashing perhaps on to the header. The car doesn't over heat or any thing. Just really annoying and I hate the smell of coolant.
Old Nov 14, 2008 | 11:12 PM
Check for leaks just after you shut it off (and still under pressure) or rent/buy a pressure tester so you can check it while it is cool.
Old Nov 15, 2008 | 12:23 AM
powerslide350's Avatar
I hadthis problem. I could have sworn it was the heater core. Hooked up a pressure tester and found a small drip from the top radiator hose pooling up on the water pump. I have a 160 thermostat on my 93 Z and with the engine at full operating temp I couldnt find the leak but Could still smell coolant, also the radiator was low. With the pressure tester pumped up to 18PSI the leak was found in two seconds.
SD WTMFW
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
