heater delete questions
Old May 30, 2013 | 10:50 AM
nikolt1's Avatar
I am deleting the heater on my 94 LT1. I already removed the heater box and blocked off the hole in the firewall. I was Just going to plug the 2 holes in the water pump. Was going to tap and plug them with pipe plugs.
As far as the bleed screw on the heater hose, can I delete that aswell? Or will there be air trapped in the system?
Old May 30, 2013 | 12:20 PM
tnyce's Avatar
Re: heater delete questions
why are you doing that its not going to gain but maybe 2hp and that's not worth the trouble.Save your money and do a heads and cam package.
Old May 30, 2013 | 12:23 PM
nikolt1's Avatar
already done heads and cam. im looking for weight savings
Old May 30, 2013 | 02:25 PM
RamAir95TA's Avatar
You can tap and plug the holes on the water pump OR loop them. Obviously tapping/plugging would look much nicer. You can deal without the single air bleed valve as long as you retain the one on the thermostat housing.
Old May 30, 2013 | 02:57 PM
nikolt1's Avatar
great, thanks! that's all I needed to know as far as having one bleed screw. I'll be tapping and plugging them today.
Old May 30, 2013 | 03:20 PM
pizzi-man's Avatar
you would get a better weight savings by laying off the beer and pizzas : )
Old May 30, 2013 | 05:08 PM
nikolt1's Avatar
lol having any luck yourself, pizza man?
Old May 31, 2013 | 10:33 AM
pizzi-man's Avatar
Well, I've laid off the beer but can't put down the Pizza
alex5366
Mar 8, 2015 11:32 AM
alex5366
Feb 17, 2015 10:43 PM
Jan 23, 2015 01:13 PM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
