heater core
Old Feb 14, 2003 | 04:30 PM
rotoruter2001's Avatar
heater core
i need to remove mine, anyone know of a good how to site for this? I have a 96 TRans Am. Thanks
Old Feb 14, 2003 | 05:11 PM
Eddie95Z28's Avatar
I wish I would document the stuff I do with pictures as I do it. then I could have a cool how-to site. It isn't too difficult just drain the coolant. disconnect the 2 hoses going to the core under the hood passenger side at the firewall. go into the car remove glovebox door and the plastic piece underneath. remove the plastic core cover box thingy. it is like 3 or 4 little bolts then you will see the core. there will be 1 clip bolt thing holding it in place remove that then comes the hard part.... manuvering that sucker out and then the new one in... reverse the process. fill up the coolant be sure to bleed the system properly and viola.
BE CAREFUL getting the new one in. You won't want to do it again real soon.
Old Feb 14, 2003 | 05:41 PM
yeah, i have checked around and all i have seen are 2nd gen heater core stuff. I am going to try flushing it, but I dont know if that will work. I just want to know how to do this in case i have to replace it. thansk.
Old Feb 14, 2003 | 07:00 PM
mkent's Avatar
make sure you flush it one way, and then reverse flush it...alternating a few times. then put it back together. i've had to do this a few times both my Z's. never have i needed a new heater core, it just plugs up. should probably just flush the entire system.
Old Feb 15, 2003 | 07:45 AM
RENE95Z's Avatar
if you are not leaking anti-freeze on the pass. floorboard, I would definately try the flush first. If after that, your heat doesn't work, get a Haynes manual. They do a pretty good job of describing and walking through changing the core out.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
