heated o2 sensor??
Old Oct 3, 2004 | 06:51 PM
1badasZ's Avatar
heated o2 sensor??
what can i do or check to fix this i guess its not heating up or something. even tho i had a bosch in it i just took it back and got a brand new one. i took the injectors and cleaned them and its still reading 450 or so and giving the dtc33. what can i check or do?
Old Oct 4, 2004 | 07:53 AM
Re: heated o2 sensor??
You say "dtc33"?
DTC 33 = Manifold Absolute Pressure (MAP) sensor circuit (signal voltage high, low vacuum)
How did you arrive at the conclusion you have an O2 sensor problem? The two are not related
Old Oct 4, 2004 | 11:33 PM
1badasZ's Avatar
the left bank reads low and doesnt "bounce" around like the right side. the right side goes from 0 to about 850 and the left stays around 430mv at idle and sometimes driving it might ease up to 720mv or so but mostly between 3??mv and 6??mv. i took the bosch out and put a new bosch in and it was the same way. so i took it out and went and got my money back and got a gm and its the same way. i gotta get this car right i got a$$es to whoop lol
Jun 19, 2015 01:34 PM
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
JurisAg02
Jul 27, 2002 11:49 AM
