Heat sink compound for ign. contrl. mod.
Old Mar 24, 2003 | 08:06 PM
  #16
There is now a small "how-to" for this.
Old Mar 24, 2003 | 09:41 PM
  #17
$hawn's Avatar
The 93's set up must be slightly different(who would of thought) anyways, my coil is directly on the head, did your originally have just the nuts between the head and bracket, or did you add the nuts and washers too? On mine the inboard part goes in this order, head, bracket, evap hose bracket, then a short bolt. Then on the outboard is, head with a stud screwed in, on that is a nut, then some little metal bracket that hold the wire harness away from the manifold, then another nut. The grounds are on some hole on the out side part of the block I think.
Old Mar 24, 2003 | 10:43 PM
  #18
The coil bracket was originally against the head. Both sides had studs that had an integral nut. So, even though your fasteners might have been a little different, they accomplished the same thing. I wonder if all 93s are this way or someone had changed out the stud on the inboard side to a bolt?
Old Mar 24, 2003 | 10:57 PM
  #19
$hawn's Avatar
So you basically just witched the nuts and bracket around then huh. The bolt on mine looks to be a factory one, and the coil was a factory one, when I first got it. Think i'll just get a stud and another nut, and some washers, so that'll be 1/2 away from the head, should disapate heat easier, plus the heat sink on the areas we mentioned above, be a happier ICM.
Old Mar 24, 2003 | 10:58 PM
  #20
Yeah, just basically moved the coil mounting to the outside of the stud nut.
Old Mar 25, 2003 | 12:40 AM
  #21
Mikey97Z's Avatar
Red face
I have been thinking about doing this, but now I'm wondering ... Why would the ICM be heat sinked to the heads if they are hotter than itself? My heads run at about 200 degrees. How hot would the ICM and coil get if they didn't have a heatsink? Maybe hotter than 200 degrees? Then spacing the bracket from the head would make them get hotter.
Any thoughts?
Old Mar 30, 2003 | 08:47 PM
  #22
$hawn's Avatar
Mikey, the ICM needs to stay cool. If there were no heat sink it wouldn't get hotter than 200 degrees, so spacing it or moving it away from the head lessens the heat sink. Anyways sense I now have some heat sink compound which I got at radio shack for 2$, I have some left from the job on the ICM and coil&brackets, what else, or where else can I use this?
Old Mar 30, 2003 | 09:02 PM
  #23
Any thoughts?
Since numerous people have cured heat related problems by spacing the ICM away from the head, I would say it would be cooler.
There are a couple of ways to think of this. The head would provide a much larger heat sink, but after it gets hot, it will retain the heat and not dissipate it very fast. I think the ICM bracket would dissipate heat faster with a little space.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
