Heard a noise while adjusting roller rocker, what is it?
Old Apr 16, 2008 | 10:58 PM
EkS's Avatar
EkS
Hey guys, I'm almost done doing my head swap. Well I was putting on my roller rockers and adjusting them. I was rotating the motor by hand using the balancer in the clockwise direction. I just got done adjusting the driver's side roller rockers. I moved to the passenger side, before I could even adjust the first set of roller rockets, while I was rotating the motor I heard this pinging noise. I felt the vibration in my hand, since I was holding the ratchet on the balancer.
So I just stopped so I don't to any damage if it's a bad thing. Did I just mess something up? What's the noise I'm hearing?
Old Apr 17, 2008 | 09:27 AM
EkS's Avatar
EkS
Anyone know what the noise can be?
Old Apr 17, 2008 | 09:53 AM
pizzi-man's Avatar
mabe a lifter turned causing the retainer to lift against the spider? Did the motor stop turning?
Old Apr 17, 2008 | 10:12 AM
EkS's Avatar
EkS
No, the motor did not stop turning, and I don't think I felt any resistance. It's hard to tell because the rockers were opening and closing on the driver's side.
Old Apr 17, 2008 | 06:59 PM
quickSS's Avatar
could be a pushrod fell out of it's pocket in the rocker. could be just a normal sound of the valves opening, (they sound like....soap bubbles popping....).
sharp ping sound though I'd wager something like the pushrod pushing against a rocker that has not been adjusted yet and it is binding.
But the fix is to eye-ball everything you just installed and certainly you'll see what could be causing the sound.
Karl
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
dfarr67
Apr 10, 2015 07:44 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
