heads on roller rockers off
Old Feb 1, 2004 | 02:12 PM
besz28's Avatar
hello yesterday i posted how my rollers seem to not be riding on the valves but on the valve spring caps. they are self alighning roller rockers from the hot cam kit. my heads now have the double springs and bigger valves.do in need shorter pushrods? will that cure all? do i need to buy 250 dollar non self alighning roller rockers?can i grind my current rockers now to work better. what have people done with this setup iam at a loss. any help would be greatly appreciated
Old Feb 1, 2004 | 02:20 PM
slopokrodrigez's Avatar
Did you read yesterdays reply on how to measure the rod length correctly?
Old Feb 1, 2004 | 02:43 PM
besz28's Avatar
yes i did thank you so much so do i need just different pushrods and all will be fine?
Old Feb 1, 2004 | 04:42 PM
besz28's Avatar
please
Old Feb 1, 2004 | 05:56 PM
joeSS97's Avatar
What exactly is the problem?Is the rocker hitting the edge of the spring?What kind of rockers?Cranes I bet.I would get some CC Pro mags if thats the case.Or is it not lining up on the stem tip?Explain...
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
