Heads for my 385
Old Jul 31, 2006 | 10:20 AM
LT4383's Avatar
Heads for my 385
I have a set of LT4 heads that were ported by Lloyd...they have 2.08/1.6 valves, 62cc chamber, 918 beehives, titanium locks/retainers.
I also have a set of CNC'ed AFR 220's that will need some touch up work, but shouldn't be anything major. I have the Jesel off set shaft mount rockers for these as well. The 220's have 2.08/1.6 valves and a 62cc chamber.
I also have a set of Gen I Dart Pro 1's, that would need a lot of work, including setup for reverse flow.
What ever the head choose I'm gonna have them o-ring so I can spray this thing hard...right now I'm thinking about spend the coin on coating some stuff as well.
The block is a 4.04 bore now and should be able to get by with just a hone job, but I'm not a machinist so ????? It has two years of race only time since the last rebuild. I'm 100% going solid roller though.
My goals are to spray this thing HARD, I have a super nice NX direct port on my ported LT4 manifold. I don't have to stick with this manifold, but would really save some $$ if I didn't have to have another manifold drilled and plumbed.
I'm really digging this heads up drag stuff, but I'm tired of bringing my knife to the fight. Mid 9 to high 8 IN DENVER COLORADO will be competitive in my class and that is were I need to be. Currently it's a high 9 low 10 car with the 385 LT4 heads and a 847 cam. I feel the first part of building a motor is picking a good head and matching others to it, so looking for any and all suggestions for this build and head choice.
Thanks,
Joey
Old Jul 31, 2006 | 05:16 PM
LT4383's Avatar
Re: Heads for my 385
Damn no opinions ??????
Old Jul 31, 2006 | 11:57 PM
RedLT4Mike's Avatar
sounds like you know what to do.
go as far as you would like to let your wallet go!
Old Aug 1, 2006 | 12:37 AM
1racerdude's Avatar
Go with the most flow. If I'm not mistaken those Darts can be made to flow about 360CFM-- maybe that's not the Pro 1's. 360CFM will make ya 740FWHP IF the rest is spot on. Keep the compression up and don't take it out because of the NO2.
The AFR's sound like a nice set up too.
Ya don't need to "0" ring it as the Cometic gaskets will hold it. They need at least a 50RA finish to work and that's for the heads too.That's pretty slick on the finish.
Ya can find a much better cam than the 847 also. IMO ya should consider a mech roller if it's allowed.
Old Aug 1, 2006 | 12:43 AM
imnotfast's Avatar
Well you have some good heads...the only one that might be a problem with lots of spray is the LT4's they have a thiner dech surface and that could be the weak link. AFR's are Darts are both great and if the ARS need just a little work have it done and go.
Old Aug 1, 2006 | 08:29 AM
LT4383's Avatar
Thanks for all the input...deck surface was another concern of mine. I'd really like to use the 220's, just seems that every where I read people say i need to have some sort of forced induction to go with those. Maybe I just need to spin it highier. ?? I'm leaning toward the 220's they flow big and there already LT style, that and the Dart's may not be off the other car untill the bracket season is over.
There's a new gasket out by SCE called the ICS Titan...I'm sold on those over the Cometics. Pricey, but there holding pressure on other applications very well! Has an internal metal ring, there a nice piece.
It will be getting Baurer solid roller speced out for it.
Should I be concerned about the intake at all? With the juice on almost 100% of the time do I really need to worry about my intake flow as much as I would on an N/A app?
Thanks again
Go Fast Take Chances!!!!
Old Aug 1, 2006 | 02:17 PM
1racerdude's Avatar
An intake that won't flow will take 12/15% off of the head flow and your HP goes in the crapper.
Old Aug 1, 2006 | 02:32 PM
LT4383's Avatar
Easy enough then...single plain will be going with.
thanks!
Old Aug 2, 2006 | 07:14 PM
SStrokerAce's Avatar
Low 9's high 8's in Denver is going to take a ton of N2O with a 3000+lbs car.
Bret
Old Aug 2, 2006 | 07:22 PM
1racerdude's Avatar
Bret
Ya'll finally get power back or did it effect ya?
Old Aug 2, 2006 | 07:24 PM
LT4383's Avatar
Bret
About 400-500; least that's what I'm planning. I've hit this short block with 300 already, but only for a bit. It was on a progressive controller, delayed and ramped. Car will lay down a 9.8-10.0 on a 225 right outta the hole. You have some cam numbers in mind... I'll be sending some PM's your way when season is over.
Old Aug 2, 2006 | 08:22 PM
I was on Vacation, no phone or internet just beach and beer. IT WAS GREAT!!!!
I figure you need a ton of power to run those numbers up in that altitude, gotta do some sort of power adder to get there.
Bret
Old Aug 2, 2006 | 08:32 PM
LT4383's Avatar
Bret
The giggle gas does seem to play a better role up here than at sea level. Even so on a small little 385 LT it's gonna take some wicked supporting mods, but I think it can be done.
95maroboi
Jun 7, 2015 12:18 PM
Red_94Formula
Mar 7, 2015 09:21 AM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
NewsBot
Dec 28, 2014 06:20 PM
