heads help
Old Jul 19, 2011 | 06:19 PM
importkiller94's Avatar
heads help
On each cylinder head there are 2 bolt holes (one in back and front) that threat into coolant passages. The coolant crossover tube threads into the back but what threads into the front holes (behind the accessory bracket and ignition coil). Are they just blocked off with bolts or does something else go there. Thanks in advance
Old Jul 19, 2011 | 06:25 PM
Re: heads help
The front holes are plugged off with pipe plugs.
Old Jul 20, 2011 | 07:44 AM
Re: heads help
What about the hole on the side of the passanger side head (where the temp gauge sensor would be on the driver side head)
Old Jul 20, 2011 | 07:53 AM
RamAir95TA's Avatar
Re: heads help
Both heads are identical, so one side has a plug, the other has the sensor.
Old Jul 20, 2011 | 09:04 AM
Re: heads help
Thanks I appreciate it
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
