heads/cam what else do i need to upgrade?
Old Dec 6, 2004 | 10:22 PM
ajschult's Avatar
heads/cam what all do i need to upgrade?
Ok, I think I'm going to go with some LE3 heads and a custom cam. In addition to this I am going to upgrade to 36 or 38# injectors, electric water pump and cloyes timing chain, new fuel pump, obviously gonna need gasket kit.
Anyone have any advice on what else I will need to upgrade?
Old Dec 6, 2004 | 10:51 PM
lifbcracker's Avatar
Re: heads/cam what all do i need to upgrade?
depending on how many miles you have, rebuild the bottom end...if you can't afford pistons - get your blocked hot-tanked, crank polished, block honed, new bearings, new rings, and get some new roller lifters, and pushrods.
I suggest building a tranny to support the power, along with a rear end.
Adjustable fuel reg. too for the injectors, and fuel pump
Old Dec 6, 2004 | 10:54 PM
dmoor88's Avatar
Comp R lifters
1.6 rockers w/ 7/16" studs (if you don't want to retain your stock 1.52's)
Hardened pushrods
Walbro 255 in-tank
Adj. regulator
Old Dec 7, 2004 | 10:46 AM
ajschult's Avatar
Bottom end has about 20k miles on it, with forged internals. Unfortunately I won't have the money to do the tranny and rear for a while.
I forgot to write comp r lifters, Lloyd reccomends getting those as well so those are on my list. I will probably get an adjustable fuel regulator as well.
Any other suggestions?
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
97SSdude
Aug 21, 2015 09:36 AM
