Heads/Cam Times?? 12.9 @ 103 ???
#32
Re: Heads/Cam Times?? 12.9 @ 103 ???
Get rid of the Accel injectors. All the major tuners including PCMFORLESS (Bryan Herter) will tell they are too sensitive and very hard to tune. A friend with a LT1 383 95 Z28 had them and got a best of 12.6 with a 306 cam and ported to death lt1 aluminums ( 282 intake/206 exhaust @,550 lift 2.02/160 valves) and had to go to 30lb SVO's to get a good tune and dropped almost a second after doing so. Ran a best of 11.70 after the injector swap on 3.73 gears in a 12 bolt conversion and t350 with 3800 stall. Now 11.0 on AI Trickflow heads and solid roller cam N/A. good luck
HVY SS
HVY SS
#33
if you dont know what the specs of your cam are, how the hell do you expect a mailorder tune to work right? and what altitude are you at? humidity level that day?
on a side note, dont stall converters screw with chassis dynos? since they dont fully lock up til ___ rpm? i dont think you could trust a dyno to tune it.
#35
4-RILLA
Yes. I have been on both forums for several years now. I have learned alot off both. They both have their good and bad points. But the only way you are going to learn is ask. You agree?
HVY SS
HVY SS
10-31-2016 11:09 AM
F(ast)-body
02-26-2003 09:05 AM
MIGHTYMOUSE
08-29-2002 09:18 AM
94LightningGal
11
07-17-2002 09:41 PM
