heads,cam,nitrous VS cam,blower,nitrous
Old Sep 12, 2003 | 03:04 PM
93formula's Avatar
which is better for a daily driver? i have heads, cam, nitrous right now but a friend has made and offer to trade my heads for his vortech s trim blower. has me tempted. i knwo the stock short block wont like boost much, but im only planning on 6 lbs if i swap. i do have another motor i was building up which can be built up for a blower with modest boost. so what would be better? this car has to be emmisions legal. the cam is a 224/236 xe cam, and the car is a m6. the blower is very tempting but will i be limiting my power band? if i run nitrous with the blower it will most likely be a 100 shot with the use of nitrous controller. thanks for your help guys!
Old Sep 12, 2003 | 03:10 PM
Gripenfelter's Avatar
What LSA is the cam? If its a 112 or less you will bleed off a lot of boost.
Nitrous is better for a daily driver.
Old Sep 12, 2003 | 03:15 PM
93formula's Avatar
the cam is 114 lsa. no i want to use the nitrous in conjunction with the blower/cam or the heads/cam. so thats not an issue. i just want to knwo if id be better off with my heads/cam or take up his offer of the heads for blower and go blower/cam route. i am fully aware that the short block wont last long but im building one up in the garage anyway. but i plan on usign 6 lbs of boost with a max of 8 lbs. im just worried about a narrow power band with the blower. how long does it take to build full boost?
Old Sep 12, 2003 | 09:23 PM
93formula's Avatar
anyone else?
Old Sep 12, 2003 | 10:31 PM
TMDZ28's Avatar
nitrous is always better for daily use
Old Sep 12, 2003 | 10:40 PM
93formula's Avatar
lol, i know
BUT what about blower/cam vs heads/cam? im leaning toward the blower/cam. and nitrous for fun
Old Sep 12, 2003 | 10:52 PM
TMDZ28's Avatar
i mean heads/cam + nitrous package is more driveable....SC is harder on the engine....IMHO
Old Sep 12, 2003 | 10:57 PM
Camaro_Maniac63's Avatar
If you are going to build a brand new short block to back it up, I would recommend the blower/cam deal. The blower has pretty much the same power range as a good cam does, so you won't be giving up too much driveability I think. Plus, a short block built for boost and a camshaft chosen for boost will also work better with nitrous. Good luck.
Old Sep 12, 2003 | 10:59 PM
93formula's Avatar
thanks, till x mas it will be on a stock short block but after the winter ill have my short block finished for boost with forged internals. looks like im going with boost plus nitrous
Old Sep 13, 2003 | 12:26 AM
D James's Avatar
I'd do the blower/cam afterall if you build the other engine for charger than you can just add moe boost for power, plus with just the heads and that blower cam your kind of limited if you want more. Do you have flow numbers or track results with the combo your running
Old Sep 13, 2003 | 01:09 AM
93formula's Avatar
no i dont have any track numbers as i was plannign on installing everything this winter then i had a buddy make me an offer to swap his blower for my heads. the heads were ported by jordon musser and look very very impressive and im sorry that i wont get a chance to try them out.
RUENUF
May 25, 2016 08:10 PM
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
