Heads and cam install???
Old May 16, 2004 | 04:02 PM
TN94Z's Avatar
Is it necessary to drain the water from the block or will draining the radiator be good enough? The reason I ask is because the nut that is around the knock sensor is stripped. Also, liquid wrench is awesome. My car has 160,000 miles on it and with the help of liquid wrench the collector bolts came right off...I figured I was gonna break them...Oh I am also doing lt's too..
Old May 16, 2004 | 04:18 PM
Kataklysm's Avatar
You'll find out if it needs to be drained from the block if coolant comes rushing out at you.
Old May 16, 2004 | 04:25 PM
simple's Avatar
may not be necessary but when i pulled my heads and didnt drain the block, #8 and #7 cylinders, water passages and head bolt holes were filled with coolant
and then after assembly for about 5 min on the 1st start up i had white smoke coming out the exhaust that scared the **** out of me, then i realized it was just excess coolant around the rings being burned off (stuff that didnt get soaked up out of the cylinders) shes fine now tho
my $0.02 is to drain the block
one thing i think you can do is start the car with a coolant hose unplugged and it will run itself dry, just dont let the car run for a very long time like that........bad things could occur (overheating)
if you do it that way, keep a close eye on your temp guage
Old May 16, 2004 | 05:30 PM
jkipp84's Avatar
Yep, drain the block. I just went through this yesterday (pulled the heads).
Old May 16, 2004 | 08:34 PM
TN94Z's Avatar
Will draining one side be good enough? I can't seem to get the drain plug out of the driver's side.
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
