Heads/Cam finished, won't start.
I'm assuming this is ignition related... Pulled a spark plug wire off and hooked it up to a spark plug and didn't get anything. So it's either down to coil or opti. Both are new, MSD Blaster Coil, hoping that may be the problem (ground or coil is just bad). I'll put the stock one back in tomorrow to see if I get anything.
Also, when I was filling up the block, I had quite a bit of coolant gush out where the thermostat sits, I'm just hoping it's not a problem with that.
I figure, even if the dowel pin was in the wrong hole (which I know it isn't) or the plug wires weren't in the right order, I'd still get some spark. So hopefully it has something to do with the coil.
Originally posted by 1FASASZ
check your ignition fuse that was my proplem
Any other suggestions?
the one that went on me was under the hood in the relay box it was a 10 amp
Chiltons Section 2-1 iirc, "Troubleshooting a no-start condition".
Best advice I can give, it is very thorough (just be careful the wire colors for the ICM weren't right in my Chiltons for my '95).
Unfortunatly for me both times it pointed me to Opti (actually to the harness connection into the opti), and both times it was right
I plan on ripping out the opti today, mess with it a little and see if I can get it to start before I put the w/p and everything back on. If not, I'll get another opti and go from there.
