Heads and cam
Old Mar 7, 2007 | 08:33 PM
Camaro350z28's Avatar
Heads and cam
i have 155k miles. Should i spend the money and get the bottom end rebuilt and then do heads/cam? or will just some lt4 heads and hotcam be safe to go?
I know the rebuild would be better and i would rather do it, but it just doesnt seem to be cheap to rebuild these things
Old Mar 7, 2007 | 08:43 PM
brain's Avatar
If you don't, make sure you at LEAST put in a new oil pump, with a white spring. It is cheap insurance. I never believed the spun bearing myth about installing cams, but after it hit me, I'm a believer. On the next motor (junk yard) I installed the GM 847 cam and made sure I did the white spring and new OEM pump. It held up to numerous 6700 rpm shifts without a problem.
Old Mar 7, 2007 | 09:20 PM
OBE1 95Z28's Avatar
Perform a compression test and leak down test to determine the health of the bottom end. FYI, LT4 heads will need a matching intake manifold so as not to block the taller intake runners.
Old Mar 8, 2007 | 02:02 AM
2000GTP's Avatar
With that amount of miles, personally I would be saving the money towards a better bottom end first, then I would worry about the heads/cam.
Old Mar 9, 2007 | 09:18 AM
Z-RATED94's Avatar
If you don't already own the LT4 heads there are better ways to go. For $200 you can pick up some stock cores and send them out to be ported. They will easily out preform a set of stock LT4s.
Old Mar 9, 2007 | 09:39 AM
94_camm's Avatar
+ 1
Old Mar 9, 2007 | 11:50 AM
BowtieCamaro6's Avatar
but doesnt it cost alot to get them ported just a wonder
Old Mar 9, 2007 | 11:54 AM
Almost Stock TA's Avatar
i think it would but i dont know how much
Old Mar 9, 2007 | 11:55 AM
69gto96z's Avatar
check out www.eportworks.com Lloyd is a great guy to deal with, and does excellent work.
Old Mar 9, 2007 | 12:12 PM
2000GTP's Avatar
A good port job by a reputable head porter will cost a modest amount of change.
Old Mar 9, 2007 | 02:40 PM
WheelmanZ28's Avatar
Mileage isn't necessarily that relevant. How does the car run? Any engine issues? oil/water leaks?
I have no idea what your goals are, but if you plan on doing a mild and streetable cam/head setup you should be fine.
The bottom end should support you fine, but you should definitely re-do your entire valvetrain regardless. springs, pushrods, lifters, retainers, etc.
Give us a lil more info as to what your planning and we can give you more advice.
Old Mar 9, 2007 | 06:19 PM
Was just looking to do something mild for the street. I do want to rebuild but dont really have the change for top and bottom. I could just save and do it all but you know how that is... I just want to do something to it! haha
Old Mar 9, 2007 | 06:23 PM
2000GTP's Avatar
You could save some money by just leaving the heads alone and making a cam only car. Plenty of people make good power with cam only applications. A good tune and the supporting bolt-on mods and you should still hit some good numbers with stock heads.
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
