Convert dual cat car to single cat?
Old Aug 8, 2003 | 04:01 PM
jchevy's Avatar
If i buy single cat headers, y-pipe, and cat-back and also convert to OBD1 will i pass emisions inspection, i will swap in the OBD2 PCM for inspection. Does anyone know if they look for both cats? When i swap in the OBD2 PCM and use O2 sims will that pass when they hook up their computer to check it?
My car needs a full exhaust and it think it would be cheaper to go this route than to keep the dual cats.
Old Aug 8, 2003 | 06:15 PM
Newbie97's Avatar
I had the same idea. Im moving to a town where emission has to be passed and I want to switch to obd1.
Old Aug 8, 2003 | 06:23 PM
madwolf's Avatar
Yes, the OBDII does look for both cats, however, you should be OK with the simulators as long as they don't do a visual check and notice that one cat is missing...
Old Aug 8, 2003 | 06:46 PM
ALEX94's Avatar
MAD
What ups MADWOLF i had asked a ? about 1996 LT1 in a 1994 camaro z28 and u said all i would have to do is change the nock sensor the exshaust and the otispark pig tail right! Well what about the 1996 LT1s crank angle sensor do i just not use it being that the 1994 does not have a crank angle sensor Thanx David
Old Aug 8, 2003 | 06:49 PM
madwolf's Avatar
Re: MAD
Yes, you can leave it disconnected. The 94 computer will ignore it.
Old Aug 9, 2003 | 12:44 AM
ALEX94's Avatar
kl
Thanx i was just wonderig: Did;nt mean to butt in!!! .........O yeah what kinda HP u think i will be running with a LT4 hot cam and 1.6 roller,cold air intake moroso peace David
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
