Heads on backwards... I'm dumb
Old Nov 20, 2007 | 12:02 PM
  #16
aboatguy's Avatar
Originally Posted by Javier97Z28
Wrong, and wrong.
The heads are the same part numbers, therefore they *must* be reversible. There is no "left" and "right" head.
I agree the heads are identical hence they are reversible; sometimes those plugs are a PITA to get out.
....and switching the heads around may end up being the easiest option. Is the temp sensor hole on the correct side not or do you need to swap the plug around there too?
Old Nov 20, 2007 | 01:28 PM
  #17
The Engineer's Avatar
Wrong, and wrong.
Javier is "right" with his two wrongs!
With all Chevy engines (SCB, BBC & LT 2nd Gens) there is only one head design (completely interchangeable) which will fit on either the left or right bank. Therefore, just remove the water-jacket NPT plugs from the rear and reinstall them in the front of the heads (much easier than swapping the heads around). You also want to use some thread-sealer on the plugs. Then install the cross-over tube in the rear.
WD
Old Nov 20, 2007 | 01:50 PM
  #18
rickreeves1's Avatar
Originally Posted by 95z28man
I'm possibly the dumbest member on this board at the moment.
I seriously doubt that.
Old Nov 20, 2007 | 02:12 PM
  #19
thesoundandthefury's Avatar
Originally Posted by speed_demon24
What size are those pipe plugs? I need to pick up a couple of them.
1/4" NPT
Old Nov 20, 2007 | 07:46 PM
  #20
95z28man's Avatar
UPDATE: failed to get the plugs out... only stripped the hole in the plug. I'm in the process of removing the heads.
Old Nov 20, 2007 | 09:38 PM
  #21
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
sorry to hear that, but javier....do two wrongs make a right
Old Nov 20, 2007 | 10:26 PM
  #22
kylersaulsbury's Avatar
Yeah I was going to say b/c you don't pull the threads out w/ the plug. But i guess it saved itself before getting to that point.
Old Nov 21, 2007 | 11:30 AM
  #23
aboatguy's Avatar
I couldnt remove the plug in the temp sensor hole on one of my heads (must have been F-body cores) and I was using pipeplug sockets like these.
Old Nov 22, 2007 | 12:25 PM
  #24
6SpeedIROC's Avatar
I used a thread tap square drive (don't know what size) that fit very tightly in there with a 12pt box-end wrench that also fit over the square part.
Those bastards were tight..thread sealant can't help either.
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Dec 28, 2014 06:20 PM
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
