heads
Old Aug 30, 2003 | 11:48 PM
jons69's Avatar
heads
Okay I have a 69' camaro, with a 350 cubic inch engine, that was produce in 78' -79'. Took off the valve covers one day, and noticed that there is a big fat LT1 printed on them. Are these actually LT1 heads and if they are did they make them in 78 or 79.
Old Aug 31, 2003 | 01:20 AM
Got-LT1's Avatar
Should be the first LT-1 (note the dash, not used in modern version). Lt-1s and LT1s don't have swapable heads. Not sure if they used the orginal LT-1s in Camaros, they were mostly a Chevelle thing. Try asking in the classic section.
texasTA's Avatar
Iknow that they used to produce a SBC named the LT1 in corvettes, but I believe that was in the 60s? Not sure. But they definately aren't going to be like today's LT1 heads. Today's LT1 heads are reverse cooled. maybe just a coincidence that they have LT1 stamped on them.
Old Aug 31, 2003 | 04:33 AM
anaik's Avatar
The original LT-1's were definitely in Camaro's and Vette's. Never heard of one in a Chevelle. !970 and '71. Yenco put some in Nova's.
Old Aug 31, 2003 | 04:36 AM
anaik's Avatar
Re: heads
They weren't made in '78 or '79, but someone could have installed them. They had big valves and flowed better than '78 smog heads.
Old Aug 31, 2003 | 02:18 PM
Got-LT1's Avatar
Whoops, the Chevelle I was thinking about was one with an engine swap, my bad.
Old Aug 31, 2003 | 11:44 PM
jons69's Avatar
I was told by the previous owner of this car, that the engine came from a vette. If they are off the vette would they be original?
Old Sep 1, 2003 | 01:39 AM
SStrokerAce's Avatar
Check the part number and what are the last 3 digits of it?
They should be a Fuelie head, like a 462 or 461 if I remember right.
If the motor did come from a Vette it was a 1970 Vette, which had the orginal LT-1. That was a 370bhp motor. They also installed them in Camaros at 360bhp and Yenko put some in some Novas that year too.
Bret
Old Sep 2, 2003 | 11:04 PM
jons69's Avatar
thanks man, I will take the cover off and look and see what the part number is. Jon
Old Sep 14, 2003 | 09:55 PM
jons69's Avatar
Part Number
The heads have several numbers on them when I took the valve covers off here they are. The passenger side head has these numbers on them/ LT 8927185 and B19-9. The drivers side head reads/ LT 8927185 and B20-9. Both heads also have GM 11, on them. How can I get info on these heads. Thanks
Old Sep 14, 2003 | 10:31 PM
EviLZ28's Avatar
going by the date codes, The heads are from 1969. The casting number has to be wrong though. Are you sure the first digit is 8 and not a 3. I know sometimes they can be hard to read. Casting number 3927185 is a good number and was used from the yrs of 1968 to 1976. It was used on 307, 327, and 350 and was a standard production head. Standard as Not high performance.
Old Sep 19, 2003 | 05:54 PM
jons69's Avatar
three
yeah that number is a three. Thanks for the info on the heads, I bet they are the originals off of the 307 that came with it.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
