headlight wont come up with switch or manually....
Old May 3, 2004 | 10:04 PM
DRIVEFASTKEEPLEFT's Avatar
ive had the problem lately where the driverside headight would make a loud noice when closing. also, both headlights would come up when i put the parking lights on. So yesterday, it never came up. went to do it by hand, and it doesn nothing. i had like 17 volts at each connector for each light. so im thinking the motor and gear in the headlight are bad? any insight would be great. thanks.
Old May 3, 2004 | 11:04 PM
kmook's Avatar
Advanced Tech Moderator
Hmm if it doesnt come up by manual turning the motor i'd guess the gear was stripped or ? Hmm Brent has helped me in all my headlight issues (I've had 3 of all 5 headlight issues weeeeeeee)
Old May 4, 2004 | 04:45 AM
Brent94Z's Avatar
Super Moderator
You had 17 volts even when the light was already down/up???
The headlight control module should have killed voltage as soon as the light got to full up/down. It could be your headlight control module is bad or it could be that the gear is just stripped. A stripped headlight gear will cause the lights to pop up/down with just the fog/parking lights coming on. Fixing the stripped gear will fix this. I have a detailed free fix that you can try. But, what has me wondering is why you still have voltage (and 17 volts at that!!!) when the light is down/up???
Once you get the voltage thing figured out, take a look here to try the free 180 degree rotate it fix
http://www.bfranker.badz28.com/headlightfix/index.htm
If you are still having trouble, let me know. As Ken mentioned, I've seen/heard about most all the headlight problems one can experience with the Pontiacs and know of a fix for almost all of them
Old May 4, 2004 | 07:38 AM
brent,
thanks a lot for the info, ill keep you posted.
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
