Headlight Replacement Question
I just recently blew a headlight on my car, what are my options as far as stock looking headlights.. ive seen halogen versions of the same rectangle lights.. if worst comes to worst ill get a stocker.. i dont wanna go to PIAAs or HELLAs i dont think.. i dont like round lookin lights they look outta place.. and i dont wanna spend an arm and a leg for lights... any help would be great.. thanks
Originally posted by BIGKerneL44
you can get those auto optiks replacements
) I had them for 2 years and finally took them out and installed Hella 90mm's (I know you don't want round, but this is what I did anyway). I looked around pretty thoroughly and the only thing that looks close to stock and has decent performance are the Hella FF75's. I chose not to get those because I don't like the idea of using driving lights for low beams and the 90mm's are the only true low beams I found.HTH
Sam
http://www.sps1.com/Head%20Lamp%20Mod.htm
Here is an option for you. However, check out your housing first. I had to replace one of my headlights because it was broke, but when I did, I found that the new headlight had an adapter on the back which allows you to just replace the bulb and not the whole housing. Goodluck.
Hurin
Dec 13, 2014 07:38 PM
Dec 4, 2014 11:56 AM
