Headlight Replacement Question
Old Feb 23, 2003 | 07:01 PM
93Z286Speed's Avatar
Question Headlight Replacement Question
I just recently blew a headlight on my car, what are my options as far as stock looking headlights.. ive seen halogen versions of the same rectangle lights.. if worst comes to worst ill get a stocker.. i dont wanna go to PIAAs or HELLAs i dont think.. i dont like round lookin lights they look outta place.. and i dont wanna spend an arm and a leg for lights... any help would be great.. thanks
Old Feb 23, 2003 | 11:16 PM
ttt
Old Feb 23, 2003 | 11:19 PM
L44's Avatar
L44
you can get those auto optiks replacements
Old Feb 23, 2003 | 11:58 PM
ive never heard of those? any pictures, info? are they brighter then stock? how much?
Old Feb 24, 2003 | 12:33 PM
Sam95ZNoTop's Avatar
Just some advice here: Do NOT get the Autooptiks!! I've had them and the only advantage to them is that you can change out the bulb. The disadvantage is that the lighting is worse than stock (if that is possible! ) I had them for 2 years and finally took them out and installed Hella 90mm's (I know you don't want round, but this is what I did anyway). I looked around pretty thoroughly and the only thing that looks close to stock and has decent performance are the Hella FF75's. I chose not to get those because I don't like the idea of using driving lights for low beams and the 90mm's are the only true low beams I found.
HTH
Sam
Old Feb 24, 2003 | 01:02 PM
RENE95Z's Avatar
http://www.sps1.com/Head%20Lamp%20Mod.htm
Here is an option for you. However, check out your housing first. I had to replace one of my headlights because it was broke, but when I did, I found that the new headlight had an adapter on the back which allows you to just replace the bulb and not the whole housing. Goodluck.
sscott
Jan 17, 2015 04:30 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Hurin
Dec 13, 2014 07:38 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
