Headlight Making Noises???
Old Oct 22, 2003 | 04:29 PM
TransAmG2's Avatar
Exclamation Headlight Making Noises???
Anyone here with a 93-97 Trans Am have problems with their headlights making noises? My drivers side headlight makes a really fast and loud vibration noise. I have an aftermarket alarm on my car which is hooked up to my lights so that when my alarm goes off, my lights will start flipping up and down. Well when I activate my alarm or turn it off to get in it makes the noise too. I was told my headlight motor is going out. What do you guys think? I already bought the motor. A guy told me his was doing the same thing and it was the motor.
Old Oct 22, 2003 | 05:02 PM
Brettinator's Avatar
it's your plastic drive gear, it just needs to be rotated 180 degrees I believe and your ok till it wears out again, then ya gotta get a new gear or motor assembly. Shoebox or someone here probably has the step-by-step on doing this, if I can find it I'll shoot it to you. It's really simple to fix...and free if it's just a stripped plastic gear.
found it...couple of options for you too...
http://www.bfranker.badz28.com/headl....htm#FreeGuide
http://www.bfranker.badz28.com/headlightfix/index.htm
Old Oct 22, 2003 | 07:18 PM
TransAmG2's Avatar
Awesome. I hope that works. I will try either tonight or in the morning and let you know. Thanks.
Old Oct 22, 2003 | 11:08 PM
95Blackhawk's Avatar
I did the trick and it worked great for me. Been going good for over a year.
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
siguy
Nov 27, 2014 10:07 AM
