headlight issue
Old Jan 8, 2004 | 07:35 PM
tkatchev69's Avatar
headlight issue
Ok, all of a sudden my main headlights are not working. My brights and my fog lights work, but not the low beams. I find it highly doubtful that they both burned out at the same time. All my fuses look to be intact. Is there something else I'm missing here?
Dan
Old Jan 8, 2004 | 08:15 PM
BlackDog's Avatar
Looks like it could be the headlight dimmer switch. Checkout this link.
http://performanceworks1.com/images/...t%20wiring.jpg
Old Jan 9, 2004 | 12:31 AM
Lt1t56's Avatar
Check to see if you are getting power to the low beam lamps, I have actually seen both lamps burn out at the same time.
Old Jan 9, 2004 | 02:16 AM
Zerosheaven's Avatar
had the same proble on a 97 maxima, it was the dimmer. you could actualy put your finger on it and switch from low to high beam and feel it clicking, switched it with a new on and worked like a charm, i actualy changed both bulbs too because i thought they both burned out.
Old Jan 9, 2004 | 06:06 AM
tkatchev69's Avatar
Ok, I want to check the dimmer switch, but I'm no good at wiring schematics. Is the dimmer switch the switch on the dash? Where is it?
Dan
Old Jan 9, 2004 | 10:21 AM
SWINGRRR's Avatar
The dimmer switch is actually the turn signal lever, or connected to it I should say. Try pulling it back towards, you, it should click. I sent you an e-mail about them, before I saw this.
Z28Freak86
Apr 28, 2015 10:35 PM
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
