headlight issue
Ok, all of a sudden my main headlights are not working. My brights and my fog lights work, but not the low beams. I find it highly doubtful that they both burned out at the same time. All my fuses look to be intact. Is there something else I'm missing here?
Dan |
Looks like it could be the headlight dimmer switch. Checkout this link.
http://performanceworks1.com/images/...t%20wiring.jpg |
Check to see if you are getting power to the low beam lamps, I have actually seen both lamps burn out at the same time.
had the same proble on a 97 maxima, it was the dimmer. you could actualy put your finger on it and switch from low to high beam and feel it clicking, switched it with a new on and worked like a charm, i actualy changed both bulbs too because i thought they both burned out.
Ok, I want to check the dimmer switch, but I'm no good at wiring schematics. Is the dimmer switch the switch on the dash? Where is it?
Dan |
The dimmer switch is actually the turn signal lever, or connected to it I should say. Try pulling it back towards, you, it should click. I sent you an e-mail about them, before I saw this.
