Headers touching the AC line?
Old Feb 7, 2004 | 09:22 AM
Mr.Whitey's Avatar
The long tubes that I installed last summer are touching the big U-shaped AC line on the back of the compressor. I'm sure others have had this same problem and I'm curious as to what you've done in this situation. I haven't worried about it until now but since I am getting the AC system charged soon, I wanted to make sure it was "OK". I don't really want to bend the AC line, so I was thining about shoving a tiny piece of some heat wrap in between the two. Any ideas?
Old Feb 7, 2004 | 09:43 AM
gb95zconv's Avatar
Ild say you need to bend the line so it does not touch then shield it.
Old Feb 7, 2004 | 11:06 AM
got_hp?'s Avatar
i carefully bent mine away as much as i could........i managed to get about 1/2 - 3/4 inch of clearance.
my AC is not nearly as cold as it was before the header install, so obviously the headers are heating it up.........so getting some flexible heat shielding would be a good idea.
HarleyZ28
Oct 5, 2015 06:23 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
Jlo
Apr 3, 2015 10:32 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
