Which headers for a stock Y pipe?
Old Mar 19, 2006 | 09:54 AM
Stoopalini's Avatar
Are the SLP 1 3/4" shorty headers the only option for mating to a stock Y pipe?
Thomas.
Old Mar 19, 2006 | 10:28 AM
GreenDemon's Avatar
Re: Which headers for a stock Y pipe?
Usually all short/mid-length headers mate to the stock y-pipe or come with their own. You could be right, most of the ones I've seen need their own y-pipe. Are you looking to keep the stock y-pipe or something?
Old Mar 19, 2006 | 11:35 AM
Stoopalini's Avatar
I have a Random Tech stainless Y pipe with integrated high flow cats bolted up to the stock manifolds. I have the car torn down right now (tranni out, oil pan loose) and I'm getting ready to take the timing cover off too. During this process, I decided to remove the AIR system, and when I pulled the adapters off of the manifolds, the threads in the manifold got stripped out.
I was planning to do SLP shorties at some point, figuring they would be a good match with the Random Tech pipe. Now that the AIR holes are stripped on the manifolds, I'm debating doing the headers now. If not, I'll have to figure out a way to plug those holes (can cast iron be welded to??)
SLP shorties are about $650 with ceramic coating, and I was just wondering if there are any other options out there.
Thanks,
Thomas.
Old Mar 19, 2006 | 12:39 PM
sssalah's Avatar
Thanks,
Thomas.
There are other options for short headers otherthan SLP. Hooker, BBK, Edelbrock, Pace Setter & JBA are available for dual cat y-pipe configuration.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Jason Short
Jan 19, 2015 06:34 PM
thenewkid
Nov 18, 2014 12:57 PM
