Headers Help...
Old Apr 12, 2003 | 05:05 PM
Laymaster's Avatar
Headers Help...
On the passenger side, how do you get the two front header bolts in? I'm installing MAC Headers and I'm using Stage 8 Locking header bolts...
I've yet to get to the driver's side at all, but from what I've read that side is cake.
Old Apr 12, 2003 | 05:18 PM
Scott 97 Z28's Avatar
You can't tighten any of the header bolts until they are all started. If you do then you will have a problem getting things to line up properly.
Old Apr 12, 2003 | 05:22 PM
stevil's Avatar
Heh, I remember that being a PITA...
The one towards the rear, I forget, did it somehow. Once you get the bolt started, try using an allen wrench to tighten it since there isn't much room for a socket or wrench.
The one towards the front. Stock setup used a special bolt to hold an alternator bracket, if I remember correctly. Tough spot, find someone with small hands. I meant to reuse the stock bolt instead of a Stage 8, but it was a PITA. I think the Stage 8 was difficult too. I ended up using just a regular stock header bolt, I should have kept trying the special bolt. Alternator has been fin without that extra support btw.
Good luck.
Old Apr 12, 2003 | 05:59 PM
Laymaster's Avatar
LOL Stevil I love your avatar, Toonces the Driving Cat...
Anyway, I have the back four bolts on, I've been using an allen wrench to do the dirty work, but the front two on the passenger side were being a pain, and it was time to pack it in anyway. I've already used a 'tap' and fixed some threads I messed up, and I don't want to be going there again (removing the header). I'll try the stock bolt tomorrow, it seems near impossible to get to with the Stage 8 unless I remove the power steering/alternator bracket..
Old Apr 12, 2003 | 06:36 PM
Lost's Avatar
remove the bracket.. it's not that big of a deal... don't reuse the stockers either... that's not a good idea
Old Apr 12, 2003 | 06:50 PM
thebrainhart's Avatar
I used the Stage 8 bolt, and screwed the alternator bracket. I used an allen wrench to start, and tighten it. It took a LONG time, because you can only get 1/2 inch of turn, but it came. I also used an open end wrench to do a little.
My alternator is still fine too.
Old Apr 12, 2003 | 09:13 PM
Z95m6's Avatar
I left off my alternator bracket too.
Old Apr 12, 2003 | 09:55 PM
Bud M's Avatar
Me too.
colts0455
Jul 28, 2015 11:28 PM
realistyc
Jul 28, 2015 07:32 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
