Headers dont look like they are sealing
Old Sep 13, 2004 | 07:05 PM
cmking26's Avatar
I just put on pacesetter shorties but to me it looks like theres a gap against the head. Like they are not sealed up good. I can't run it yet cuz motor is not altogther yet just curious if anyone has had this problem or if it just looks like it aint sealed but is. I used copper D port gaskets if that matters.
Old Sep 13, 2004 | 07:10 PM
simple's Avatar
Re: Headers dont look like they are sealing
copper gaskets are tought to make seal right, ie not very forgiving
could also be a warped or bent flange, put it against a straight edge to check
Old Sep 13, 2004 | 07:35 PM
Kataklysm's Avatar
Change the gaskets while you can! I had copper header gaskets and they leaked in the first 2 weeks (bolts did not back out either) I changed to the paper ones nobody likes and they work far better.
Old Sep 13, 2004 | 09:32 PM
Spinner's Avatar
I used earls dead seal after I couldnt get paper, copper, or felpro/mr.gaskets to work. They're aluminum, with silicone/graphite inserts that are seperate, that seal around the ports. beautiful pieces, expensive, but no leaks. they're awesome!
Old Sep 14, 2004 | 04:05 AM
cmking26's Avatar
I think I figured it out. The headers oval ports had a little extra material so they were thicker. I think that is why the flange looks like its pulled away.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
