header question
Old Nov 20, 2005 | 02:01 PM
ttop1986's Avatar
header question
Im still trying to get my passenger header to fit right. It touchs the floorboard by the collecter. I already have the driver side one in and it fits perfectly, which gives me reason to believe my motor mounts are in good condition. Im worried if i try to change the mounts then i will have fitment issues with the driver side too. Or is it best to leave it and pry the passenger side collecter down a little? anyone run into a problem like this? EDIT: There is also plenty of clearence on the passenger side primarys and the K member.
Old Nov 20, 2005 | 02:48 PM
RedRyder518's Avatar
Re: header question
What headers are you running?
Old Nov 20, 2005 | 02:57 PM
ttop1986's Avatar
Re: header question
pacesetter longtubes. ive had a hell of a time with these things because the first set i got was defective, now these need some adjusting too, but they arent as bad as the first set. these seem fixable.
Old Nov 20, 2005 | 03:14 PM
2000GTP's Avatar
Re: header question
Are you talking about the collector hitting the heatshields? If that is the case, I had to modify the heat shields some in order for them not to touch the header collector. Other people remove them altogether.
Old Nov 20, 2005 | 03:48 PM
ttop1986's Avatar
Re: header question
i removed the shields and its still touching. which is why I may have to bend it downward a little.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
