Header Problem!!!
Old May 4, 2008 | 07:11 PM
camarostripe96's Avatar
From: Academy,tx (Home to Temple/Academy Drag Strip)
Header Problem!!!
ok i installed Long tube pacesetter headers today on my 96 trans am, and i used mr gasket copper gasket, and i cranked it up without my o2's plugged up and first all , i have exhaust leaks around the headers and my bolts are tight, so i guessing its the gaskets? and whenever the cars running i have a ticking noise coming from the driver side header, and the more i give it gas the faster the ticking gets.... what is causing this? anyone have an idea? i have ngktr55 in it, but havent changed the plug wires , i am waiting on them to get here....so anyone have an idea?
Old May 4, 2008 | 07:39 PM
Kevin Blown 95 TA's Avatar
I used those copper gaskets and they leaked around the bottoms of the ports of my SLP headers because they were shaped wrong for the header to exhaust port seal that was needed - maybe you have the same problem.
Old May 4, 2008 | 09:15 PM
MeanGreen97Z's Avatar
I thought I posted a reply to this? Anyway... are you sure you cleaned the gasket surface on the head? There was a bit of baked on old gasket when I did mine and it leaked like crazy.
Old May 4, 2008 | 11:37 PM
no there is not old gasket on there, i cleaned the heads and everything before i put the new headers and gaskets on, and yes kevin blown 95 TA, my headers on the top port are leaking pretty good and the bolts are tight, i have the same gaskets
Old May 5, 2008 | 06:06 AM
The ports are "D" shaped and the header flangess are "O" shaped and the gaskets are "D" shaped more or less, and so the header flange opening crossed over the raised bead on the gasket and created the leak in my application, anyway. You can see it on the bottom where it's all black.
Old May 5, 2008 | 07:10 AM
94zgreenmachine's Avatar
Try these from Summit. http://store.summitracing.com/partde...A3BERL&FROM=MG
Stay away from Percy dead soft aluminum. Not the answer either.
Old May 5, 2008 | 12:56 PM
What bout felpro gaskets?
Old May 5, 2008 | 03:23 PM
caldercay's Avatar
Originally Posted by camarostripe96
ok i installed Long tube pacesetter headers today on my 96 trans am, and i used mr gasket copper gasket, and i cranked[snipped]
I've heard a number of folks complain about those gaskets.
Felpro 1470.
Old May 5, 2008 | 03:29 PM
2000GTP's Avatar
I've been completely satisfied with their header gaskets.
Old May 5, 2008 | 04:00 PM
What's the difference in felpro 1405 and 1470 ?
Old May 5, 2008 | 04:09 PM
2000GTP's Avatar
I'm guessing you are referring to the Felpro 1406s. I am using the Felpro 1406s, although there are several members using the 1470s as well.
Old May 5, 2008 | 07:27 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I've read very few complaints regarding the Percy's Dead Soft Aluminum gaskets. After much research, they are the gaskets I chose.
Old May 5, 2008 | 10:03 PM
ok well i got the felpros 1470 today, gonna try them out and if not then i am moving on to percys!! i guess i will be testing them all out LOL HAHA
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
