header leak question
Old Jul 18, 2004 | 12:47 PM
customlt1's Avatar
Recently got hooker long tubes installed and at the same time 02 and extensions..after this my check engine light came on..i have a leak i believe on the passenger side on headers and just need a new gasket..my codes got scanned and it came up that one of the 02's was leaning out..at idol it was now getting enough and at higher rpms it was a little bit better..clynders 4 and 7 were also missfiring at times..would this probably be from a leak in one of the headers? thanks alot
Old Jul 18, 2004 | 02:40 PM
Loadre's Avatar
The misfire is most likely a burnt plug wire. An exhaust leak will sound like a loud ticking. Ride with your windows up and see if you can hear it.
Old Jul 18, 2004 | 02:55 PM
customlt1's Avatar
i changed the plugs and wires when the headers were being done..when hooked up to a computer the missfire was only occuring at idoling..
Old Jul 18, 2004 | 03:04 PM
Both an exhaust leak before the O2 sensor, and misfires will cause the O2 content in the exhaust to rise, and the O2 sensor will report a "false" lean condition. The result is the PCM richening up the mixture, and now the entire bank is running rich. Fix the exhaust leak. Track down the misfire - plug could have cracked when being installed, gap might be wrong, wires could be burned, wire (or terminal on plug) could be loose..... lot's of things.
Old Jul 18, 2004 | 03:06 PM
customlt1's Avatar
okay i'll check the wires..i was wondering if it was just from the exhaust leak thou.....
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
pologreen97z
Dec 2, 2014 10:42 AM
