Header install, now have miss?
Old Nov 4, 2006 | 11:01 PM
dlricker's Avatar
I just installed some pacesetter headers "non-emissions" with offroad y-pipe. The car pulls hard with no miss 1-2, 2-3, 3-4. No miss at all, but if lets say if i'm crusing in fifth gear and need to pass someone without dropping it down a gear, and put the engine under a good load, it has a real good noticable miss. Anything i need to check? Plugs and wire connections seem to all be good, is this something the ecm needs to relearn or something, all the help will be nice. Thanks, Daniel
Old Nov 4, 2006 | 11:13 PM
ttop1986's Avatar
You may have to disable the EGR in the computer tune.
Old Nov 5, 2006 | 12:04 AM
dlricker's Avatar
no, i found a plug wire terminal was turned and was not clipping onto the spark plug, also it got burnt by the header. Well any answers to a set a spark plug wires to help out this problem?
Old Nov 5, 2006 | 08:14 AM
jjminch's Avatar
I had a good results with the accell extreme 9000 model. Different car, but they didn't fry very easily
Old Nov 5, 2006 | 12:19 PM
2000GTP's Avatar
Heat sleeves and cable ties should help out quite a bit. You may even consider doing a over-the-valve cover wire setup in the future to avoid the problem of burning wires altogether.
Highlander
Jan 12, 2020 02:13 PM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
Collector Car
Jan 5, 2015 10:58 AM
