Header install on a 95 z
Old Jul 19, 2007 | 03:53 PM
a4z28's Avatar
I have a quick question about headers maybe someone can help me with. I wanted to know if i installed the pacesetter race version with out no egr or air can i use it with out a tune and what would i need to do to block the egr and what ever else needs to be done.How long do u think it would take to do the install. thanks
Old Jul 19, 2007 | 04:24 PM
2000GTP's Avatar
Depends, as long as you keep a good fuse in the AIR circuit, you shouldn't get a code. However, the EGR is a hit or miss. If you get an SES light, then you will have to have it tuned out. You will also need EGR blockoff plates which run around twenty bucks. The install can take a day, or it can take a little longer, it really depends on you.
Old Jul 19, 2007 | 04:44 PM
a4z28's Avatar
But as far as the egr is concerned i wiil only have to block it on the intake manifold. The air pump i could just delete untill i get a ses or a tune as long as i have a good fuse like u said.
Old Jul 19, 2007 | 05:11 PM
a4z28's Avatar
One other thing i was wondering about is on the o2 extensions which ones do i get the flat or the square conectors i have a 95z.
Old Jul 19, 2007 | 05:15 PM
Mr_Bond's Avatar
Flat one for the front O2's.
Old Jul 19, 2007 | 05:41 PM
a4z28's Avatar
Once i get the install in order with the ory with no cats will i be able to start my car and drive it or will i need a tune cause of no cats.
Old Jul 19, 2007 | 08:48 PM
2000GTP's Avatar
The cats won't be an issue, you can drive the car. Plus, you have a 95 so the PCM doesn't even monitor the catalysts.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
